FM 107 cylinder base leak
Hey guys I'm working on a 08 night train. We built a FM 107 for it a few months ago. The bike runs amazing but after 1300 miles we're seeing seepage from both cylinder bases. I know this is a common problem but this is the first time I've experienced this on an engine I built. Anyway my point of this post is do any of you guys have any advice on what I can do to avoid this in the future? I've ordered a new gasket set and will start tear down on this one tomorrow probably. FM mentioned using hylomar on the base. Anyone tried this before? I'm not sure I understand exactly what he meant so curious if anyone's tried this or if you guys have any other fixes. Thanks for any advice you guys can give.
We generally use a very light film of Hylomar on the cylinder base along with an OEM Harley O-ring. Please give us a call back and I can get you with Keith and he can explain everything. We can also get you setup with the necessary gaskets and O-rings.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
I think it was Bob that I talked to. He was very helpful and even gave me the hylomar part number you guys use. I also ordered the gasket set during the same phone call. Everything he said made sense until we hung up and about 5 minutes later my mind said "wait a minute" lol. I think I got it though. Just need to see it in front of me again and I'm sure it'll all make sense. Thanks
I agree, if the mating surfaces are free of imperfections, heads are torqued properly and the studs aren't pulled there should be no need for anything other than the stock "o" ring. Inspect well
Will do guys thanks. The bike only has around 13000 miles on it. No leaks before the build and we're using the IC cylinders on it. Hopefully if we made a mistake somewhere or if there's an imperfection we'll find it. What also made me wonder is it didn't come from any one area. It seems to be seeping pretty evenly around both bases
Originally Posted by fuelmoto
When you get it apart give us a call, we certainly want to assist in determining what may have caused the leak.
Not a normal occurance, and that ancient Rolls-Royce engine sealer is not the cure.
The cylinder bases may not be perpendicular to the bore, or as Kirby has mentioned, some other oddity or flaw.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
