Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
You can always cut your tubes shorter. But some tape on the line so you won't mess up the powder coating
The lower tube is too long and won't slide up far enough to access the adjuster. The lower tube is flared for the O-ring so cutting it down is not an option. S&S says "1984-'99 style pushrod covers are required for access to the Quickee Adjustable Pushrod adjusters in 2007-'12 big twins."
Engine is basically together, ready to prime and fire up. Finished up with the primary over the weekend and buttoned it up Tuesday night. Installed a 30 tooth trans pulley, Barnett clutch and billet basket, and a SE compensator with a Game Changer sprocket. During the waiting time I decided to go ahead and convert to hydraulic clutch and run everything internal in the bars since I been piecing stuff together for that project for a while now, so I have to get that finished up. Decided to scrap the Rineharts and go with a Rush Wrath. Also decided to work with Daren at Sheffer Performance for the tune. Nothing real interesting happening until I get her fired up.
