Engine Crankcase Identification
Old 06-09-2017, 10:52 AM
Tkimble01's Avatar
Tkimble01
Tkimble01 is offline
6th Gear
Default Engine Crankcase Identification
I have a cusotm Harley Chopper built in 2007. The numbers on the front lowere left and right of the crankcase are AB07H5932. Can anyone tell me how to decode this to determine what engine I have.
Thanks
Tom
Old 06-10-2017, 06:13 AM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,031 Likes on 652 Posts
Post a picture of the crankcase
Old 06-13-2017, 02:37 PM
Tkimble01's Avatar
Tkimble01
6th Gear
added pics of engine. Anyon know what this is? It does have an S&S carb and an ev27 cam if that helps.
Old 06-14-2017, 02:24 PM
Zanthamos's Avatar
Zanthamos
Zanthamos is offline
The AB crosses to a Police model Electraglide (FLHP), but the 0 doesn't cross with any engine size and the 7 is the start of the serial number unless it is an S&S or other aftermarket engine.
Old 06-15-2017, 11:58 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,302 Likes on 3,658 Posts
These aren't HD or SnS cases. Probably ultima but could be Sputhe, Delkron, or some other case.. Since it has a Ev27 cam, I would suspect that it's probably 80 ci.. Cylinder deck looks to be standard so it can't be much more than a 96 ci motor.
Old 06-15-2017, 12:23 PM
brad75raiders's Avatar
brad75raiders
brad75raiders is offline
The Ultima has a smooth finish about .5 inch on both sides were the cases bolt together. The cases on this bike look like they are walking or just have a bad cast. Edit polished Ultima cases don't have the .5 inch finish. So it could be Ultima
Old 06-15-2017, 01:39 PM
lt1-xjs's Avatar
lt1-xjs
lt1-xjs is offline
There are 2 threads on this.
Richard Riddle
Engine Mechanical Topics
13
01-28-2021 03:07 PM
Tkimble01
06-14-2017 06:32 PM
Lawdawg
03-27-2015 02:12 PM
customsoftail200
16
06-07-2014 09:17 PM
Grizzwood
03-05-2011 04:12 PM
Quick Reply: Engine Crankcase Identification
