Screamin Eagle Stage 3 Kit 103 performance Upgrade
Old 06-25-2017, 08:02 PM
Ronald Hawkins's Avatar
Ronald Hawkins
Ronald Hawkins is offline
2nd Gear
Default Screamin Eagle Stage 3 Kit 103 performance Upgrade
Has anyone had one of these kits in their bike? I have a 2014 roadking. The kit comes with SE-585 cams, high performance valve kit, perfect-fit pushrods, top end gasket kit & heavy duty clutch spring kit. If someone has had this kit in their bike please let me know how it worked with ur bike thanks
Old 06-25-2017, 11:00 PM
2009blackpearle's Avatar
2009blackpearle
2009blackpearle is offline
Default your better off with expert eng builder
you would be better off going to expert engine builders like hillside there was a post in fall guy gets stage 4 kit 585 cams , was a dog takes bike to hillside bores to 107 reworks the se pro cnc heads , changes cams to andrews 57 cams, uses the 58 mm intake that came with the waste of money stage 4 kit, bike puts out 125hp 125 tq
se kits yield very small returns on power for the money
guess this answers your Andrews 57 post too
Old 11-23-2017, 07:40 PM
Scott F Hoffmann's Avatar
Scott F Hoffmann
Scott F Hoffmann is offline
Stage II
Default 103ho stage 3
Hi Ronald, I have put this on my 2014 FLHTCU. Love it. So as a comparison, I drove a stock 107 Road Glide Ultra and a 107 FLHTCU. The Road Glide is 100 lbs heavier than a FLHTCU, I found the road glide a bit of a dog, my stage 3 103 puts me in the seat when I crack the throttle, the Road Glide did not. Then I tested the 107 FLHTCU and while it was better than the Road Glide the 103HO with the stage 3 has way more torque. Now if you went from a stock 103 to a stock 107, you would definitely notice the difference in torque. I will keep my 103, the 107 bike looks the same, but the 103 upgrade is worth it!
Old 11-24-2017, 06:19 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
I agree with having a 107" built to your riding style over a "cookie cutter" SE kit
tylerwest84
03-02-2017 07:52 AM
Hrdhtdvr
Exhaust System Topics
01-12-2013 10:57 AM
dlrshort
10-16-2012 10:07 AM
Jetblack3
06-25-2012 10:59 AM
oilhog
06-08-2007 02:36 PM
Quick Reply: Screamin Eagle Stage 3 Kit 103 performance Upgrade
