Twin cooled
Does any one kno what cc’s the stock combustion chamber size is on a 103 twin cooled engine.I purchased a set of cnc ported screamin eagle heads and im tryin to figure out what the size of my stock heads should b and if these have been milled ? Thanks for all replies and info !
IIRC, no different from the air cooled 103 heads; 85cc-86cc.
My head porter did a "light cleanup cut" on the sealing surface, arrived at 84cc.
'15 wethead. YMMV __________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters |
Originally Posted by djl
(Post 16858044)
We've had many come thru here, but have never cc'd them, prior to beginning work on them.
If you've cc'd them, and 78 is your number, then they have been surfaced about .040", +/-. Scott |
Originally Posted by Hillsidecycle.com
(Post 16859520)
Originally Posted by Clayton24
(Post 16858137)
oh ok thanks i was thinkin thats how they raised the compression compared to the air cooled ! I cc’ed the screamin eagle heads and keep comin up with 78 cc .
(Post 16859808)
HD lists compression for both 103 motors, air cooled and twin cooled, at 10:1; compression is the same for both.
(Post 16859829)
oh i thought air cooled was advertised at 9.7:1 an twin cooled at 10:1?
(Post 16860100)
Not the HO103 motors; both at 10:1; the "regular" 103 is, as you point out, advertised at 9.7:1.
© 2024 MH Sub I, LLC dba Internet Brands
