? about the different big bore kits for 88 twin
Nice ride.
95" kit is standard BB kit from the MoCo; has been since the TC88 was introduced; typical MoCo strategy; sell an under powered TC88 but offer a 95" BB kit to bring the power. .......................So, check the crank run out as part of your familiarization with the bike to establish a baseline for future reference.
01HeritageJJP (09-23-2020)
EL in NH (01-03-2018)
perfect..that clears it up for me. The first thing I noticed was how much more oil this bike uses per thousand miles than any other harley I own. I assume the valve stem seals are the culprit. That and the tensioners need to be addressed. I had so hoped that I would be able/willing to leave this completely stock as it is now...no that's not happening.
The following 2 users liked this post by djl:
EL in NH (01-03-2018),
RoadKingKohn (12-07-2022)
Big Bore Options
Concern I have is that my ‘96 Twin Cam 88 has 105,000 miles. My compression even at about 130 per cylinder.
Bike runs great and untouched.
Given the high miles, might I be overdoing this engine with risks of high mileage weaknesses anywhere.
I was worried about the bottom end.
your thoughts and points of view?
Thx
Jim
Thx
Jim
You've accumulated a lot of miles on that bike, which implies to me you're happy running it with a stock amount of power.
When my dad bought an 04 Ultra with 88K miles in 2012 we did a full rebuild with a 95ci kit using CAST pistons, Andrews 21 cam (gear drive), mild headwork (I cleaned up the valve seat area and put new seals in), and had Darkhorse rebuild the crank and put some take-off HD rods on with a balance to the cast pistons as well as bore the OEM cylinders at .001" clearance. John himself said the HD rods are said to be good for 150K. That's NOT to say they'll immediately fail over 150K, but it does say their ability to perform under higher stress situations can be called into question. That bike still runs like a top, very streetable, doesn't require 91 octane, and smooth as silk. A great, mild, reliable bagger motor.
My point here is don't build the bike into something you're not going to enjoy and appreciate. I must honestly admit to over-building some motors only to regret going that route because even though the new motor rips, it's not as "streetable" anymore. Not to mention, they're cheaper to build.
Prodigal_Sun (01-29-2020)
It looks like Wiseco makes a 4.25" piston that is made for use with a 4" stroke (the std. 88 stroke), which will render just under 114 cubes at 10.5-1 comp. Of course the crank case would have to be bored out to make provision for the larger O.D. of the bottom end of these much larger sleeves. Does anyone know if such a critter has ever been built and was it a worthy exercise? On another note re. boring crank cases to allow for such large lungs, Have any of you all heard of anyone doing an "in fame" bore job on these crank cases. I'm an old automotive machinist and have looked over the shoulder of tool & die makers in my time and I think I may know how to create the tooling that would enable a machinist to do this task without an engine re & re and tearing down the engine, and therefore eliminating a lot of hours. Rather than a boring bar & tool bit, I believe I could create a rotabroach device that can straddle the con rod instead of removing it like the conventional method. If this hasn't been perfected yet,would it not be a breakthrough specially for those on a budget?
Bigger is better and more is never enough!
Prodigal_Sun (08-09-2019)
It looks like Wiseco makes a 4.25" piston that is made for use with a 4" stroke (the std. 88 stroke), which will render just under 114 cubes at 10.5-1 comp. Of course the crank case would have to be bored out to make provision for the larger O.D. of the bottom end of these much larger sleeves. Does anyone know if such a critter has ever been built and was it a worthy exercise? On another note re. boring crank cases to allow for such large lungs, Have any of you all heard of anyone doing an "in fame" bore job on these crank cases. I'm an old automotive machinist and have looked over the shoulder of tool & die makers in my time and I think I may know how to create the tooling that would enable a machinist to do this task without an engine re & re and tearing down the engine, and therefore eliminating a lot of hours. Rather than a boring bar & tool bit, I believe I could create a rotabroach device that can straddle the con rod instead of removing it like the conventional method. If this hasn't been perfected yet,would it not be a breakthrough specially for those on a budget? Bigger is better and more is never enough!
Thanks for the reply, I guess I should have stuck to one question at a time. Are you referring to my question about putting 4.25 bore on the 88 or my notion of creating the tooling to machine the crank case in frame? If you're referring to the 4.25 bore,can you tell me what the negative results were that you heard? I did wonder if it would just be more than what that bottom end was engineered to endure,(all those cubes)-- but I just don't know.
Thanks for the comment on these points. This makes sense,you drew the picture in my minds eye that points out just such a thing that I thought may be the case and demise of going down that road I was looking at. So as I thought may be the situation, just too much top end for the bottom end to endure. Reminds me of my rifle re- loading hobby, "If you want to make a 30 caliber 160 grain bullet reach high velocity (say--3400 feet per second), don't overload your little 3030 winchester rifle cartage with powder, go get a 300 win magnum that's designed to withstand this big powder charge and pressure".
Nice chatting with you who speak the same language, knowledge really IS power!
