install stage iv
have a 2015 cvo street with vance and hines true duals with hi output mufflers, se super tuner. dyno at 88.85 hp and 108.57 torque. if I go to a stage iv will I get around 110 hp and 115 torque? Is it worth the cost?
Originally Posted by rickwyl
(Post 17926122)
The MoCo claims the CVO 110" motor delivers 115TQ in stock trim. Sounds like you went backwards with your Stage I upgrade and tune.:icon_doh: was the tune done by the dealer? Is the dealer pushing the Stage IV kit?
110/115 numbers are easily achieved with headwork, cams and proper dyno tune (not a dealer tune). Two forum sponsors can inform you on how to get the numbers you want. Talk to Scott/Hillside Cycles and Kirby/VeeTwin Performance; chat them up and work with one of them to get what you want. We are basically talking about a top end rebuild which you can DIY or find a local independent shop that works primarily on Harleys and has a good track record. |
You install cr575 cams retune and that’s it. 120tq 105hp. Cheap and easy. And you’ll beat a SE kit light to light |
Change your exhaust first if you’re looking for real performance. |
https://cimg3.ibsrv.net/gimg/www.hdf...84d786034a.png
Here is a cam only 110" we had to fix, the engine lost a lifter and took out the cam chest. While going back together we threw in a Red Shift 587 cam along with the S&S pump/plate, lifters, pushrods and whatnot. The bike had the stock 110" intake and a Fat Cat exhaust....I post this for reference. Last but not least, many thanks to Steve at GMR for the great tuning on this for us!!! |
(Post 17926122)
Harley dealer quoted $4100.00 |
The MoCo claims the CVO 110" motor delivers 115TQ in stock trim. |
(Post 17927631)
© 2024 MH Sub I, LLC dba Internet Brands
