Checking deck height
Hello everyone. I'm getting ready to do a topend rebuild and cam on my 1994 Road King and although I have done a bunch of research and watched many videos, I'm sure I'll have some question.
My build consists of Hillside headwork, 10:1 pistons, a woods w6 cam and a thunderjet for my s&s super e. I am also adding a dynatek ignition and I'm tuning it with a wego 3. My first question is about checking deck height. I bought a zippers deck height tool and a good straight edge to make sure I set my squish correctly. Since my pistons will already be installed in my cylinders when they come back from Hillside, can I install them without installing the circlips so I can measure deck height without the base gaskets? Then I can pull the piston pins and add the correct combo of base gasket and head gasket to get the squish right. Geegg My first |
Yes, you can, you could even install only one of the clips, measure, then remove. Make sure you plug any openings in the engine when your put the clips in, so if you drop one, it does not end up in a bad place.
Originally Posted by Yankee Dog
(Post 19665840)
Originally Posted by Ropestringer
(Post 19665770)
Originally Posted by OldMike
(Post 19665962)
I'm doing a similar pistons-in-cylinders from a different shop. One clip will already be installed so will do a mock-up with just the pin installed and no base gasket. I already had a depth gauge and micrometer to play with. Just using some PVC pipe sections to hold the cylinder.
(Post 19665978)
Awesome, I'm still several weeks out on mine but I'm getting excited. The deck height tool from zippers comes with aluminum spacers for holding the cylinders down but I used some half inch drive sockets on my last build.
Ya, I'm ahead of my cylinder/piston delivery, just getting prepared. |
I measured mine with a straight edge and feeler gauges...I also used the cut pvc tubes to hold the cylinders down. Worked fine for me. The zippers tool is nice, but I just "improvised". YD
(Post 19666097)
(Post 19666097)
(Post 19666544)
I guess my main reason for getting the zippers tool is so that I can accurately determine TDC before measuring deck height. I suppose I could use a feeler gage and straight edge if I had a helper but it seems like it'll be easier to turn the wheel and look at the gage. I used a straight edge and feeler gages last time and I came up with different measurements every time I measured. I ended up just averaging them.
EDIT: Because I do have an inexpensive dial depth gauge, I tried it to get TDC and can easily hold the indicator and turn the rear tire. https://cimg3.ibsrv.net/gimg/www.hdf...bad8239f46.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
