Exhaust System Comparison/Explained
Old Jun 30, 2005 | 11:01 AM
HDF Tech's Avatar
HDF Tech
Default Exhaust System Comparison/Explained
Harley Exhaust Comparison
Harley exhaust choices vary almost as much as those who ride. Drag pipes, slip-fit mufflers, 2-1, staggered duals, and the list goes on. An exhaust system is made for every bike, engine, style, and configuration imaginable. However, there is a big difference between performance and what looks "cool". If you are contemplating the purchase of a new Harley exhaust system you should first ask yourself a few questions.
How important is performance compared to looks?
Are you looking for performance in low to midrange or high end torque?
Is your idea of "Hi-Performance" a Cable TV show theme bike?
If you answered yes to #3 then you're probably going to put whatever looks cool on your bike and not worry about how it runs. For anyone interested in what will improve performance or why those drag pipes made your ride a slug please read on.
Let's start with the basics. Without getting into a lesson in physics there are three factors that effect the performance and tuning of an exhaust system. Sonic pulse, thermal pulse, and exhaust gas velocity.
Sonic pulse. Think of this as a shock wave. This pulse travels through the exhaust and at the end of the pipe actually turns around and heads back toward the exhaust valve. The wave will also pull exhaust gas back along its path and if it reaches the open exhaust valve the gases will dilute the air/fuel mixture in the combustion chamber. Under the right (or wrong) conditions this wave will even push some of the air/fuel mixture back through the intake valve into the intake, a common occurrence with short drag pipes.
Thermal pulse. Similar to sonic pulse, this is a wave created by the hot gas exiting the exhaust valve. The thermal pulse also reverses direction at the end of the pipe but unfortunately travels at a different rate, thus reaching the combustion chamber at a different time.
Exhaust gas velocity. This is the rate at which gas travels through the exhaust system. The optimal velocity is 300 feet per minute. For the most part all stock Harley engines require a 1-3/4" diameter pipe to maintain 300 fpm. Bigger is not always better and a larger pipe will actually slow this velocity thus restricting flow.
So what does all of this mean? To best answer this question let's look at a few different exhaust designs and how they handle the above listed conditions.
Short Drag Pipes
Since the sonic and thermal pulses don't have as far to travel as in a longer system the wave is able to return faster, thus entering the combustion chamber robbing the engine of power. Drag pipes are tuned for higher rpm large displacement engines where these pulses can be overcome.
One trick is to install anti-reversion or torque cones. When installed inside the head pipes these cones act to repel the pulse waves as they return to the engine and alter velocity as the gas passes through the narrower passage. Performance will still suffer on the lower end since there is no ability to scavenge gases as with a 2-1 or stock Harley exhaust.
Large Diameter Open Pipes
While not plagued with the same problems as shortie drag pipes, a large diameter open pipe will actually restrict flow since the optimal 300 fpm cannot be achieved. Installing larger baffles or thunder tubes will change the velocity.
Long Straight Pipes
Running long pipes without any baffles fall under the same category as Large/Open Pipes. Removing the baffle will make these pipes real loud but horsepower will suffer. Remember, bigger isn't better when it comes to diameter so stick with 1-3/4" pipes. There are drag pipes incorporating 1-3/4" head pipes and 2" mufflers such as those made by Cobra. Python³, Samson, Vance & Hines, Dyno Power, and Hooker all have excellent offerings in straight pipe designs tuned for standard displacement Harley's.
2 into1
Exhaust systems that use a single collector (2-1) are well tuned for low end torque on stoc
Charles:
Sep 15, 2019 05:22 PM
Whtwolf14
Mar 10, 2016 08:52 AM
jm04
Jun 10, 2010 12:26 PM
HDF Tech
Engine Mechanical Topics
Aug 3, 2005 12:46 AM
HDF Tech
Jun 26, 2005 12:18 PM
