My experience installing the SE 25284-11 cam kit
#31
Not to start an argument but have changed cams as many a three times in less than a year and used the same pinion and rear cam with no issues. Not suggesting anyone else follow that example but this has been my experience. Yes, I always clean the threads, both male and female. If these were high torque fasteners, maybe I would be mor concerned but considering the fine threads, bolt diameter and the 24# and 35# torque, just don't see an issue. I have always been able to apply the specified torque by holding the brake with the trans in 1st gear.
I have never "pounded" a cam shaft to install an inner cam bearing but have "tapped" them in using a camshaft after freezing the bearings over night; never had an issue either. I do have the tool now since I started assisting friends and family members with cam swaps but would not hesitate to go caveman in a pinch.
#33
#34
the one thing that no one has talked about here, is the reason for the new bolts for the pinion and cam. when i worked for the moco these were described to use as a type of torque to yield bolt, even though it doesn't say anything about it in any of the literature that i've ever seen. the cleanliness of the holes that these bolts screw into is also very important and often over looked. I HAVE seen failures related to the re-use of these items, good thing they come with the camplate kit. I also can make all kinds of work around tools/methods, but pounding on a camshaft to seat a special depth bearing is not one i would recommend for anyone but a very experienced and skilled person, also locking the pinion and cam gear with the tool allows you to get the proper torque applied to the special bolts already mentioned. If you are in an absolute pinch, you do what you have to, but to me it's always better to do it right if you're going to do it and not have any little nagging "what if" fears.
m
m
My 06 Ultra has gone almost 5 years and 30,000 miles since my install, so I think I "cavemanned" it pretty well. I will agree some of my ideas are not for everybody.
#35
Ok, now we come to removing the inner bearings and replacing. If you have an AutoZone near you they have a cool tool rental deal where you "buy" the "hidden bearing" removal tool and if you return it in pristine shape they give you your money back. It worked for me, good deal. You place this tool carefully into the old bearings, tighten the tool and then use the slide hammer to remove them. Now, another special HD tool is supposed to be used, the inner bearing installer. Ok, at this point shop mechanics will screech but I did it a "different" way! I (carefully) used the rear cam itself as a tool. I placed the new bearing on the end and sighted it straight. I used a hard rubber hammer to protect the outer end and slowly tapped both bearings in. Done! Now I've been working on my own stuff a long time and know how to go slowly and carefully doing something like this. Do so at your own risk.
Ok, now the outer bearings. I have a friend with a hyd press and he helped me press both the roller and ball bearings into their respective holes in the cam plate. Now the inner chain goes on; timing marks lined up and we pressed the front cam into the front bearing. The rear cam just slides into it's bearing at the same time. Inner new cam tensioner on. Double check the timing! As you assemble don't forget all the o-rings, especially the one on the suction of the oil pump. After the cam plate is back on, you put the sprockets and chain on (TIMING!) and tighten the bolts with the tranny in gear. Outer new cam tensioner on. Cam chest cover.
1. After I installed the new inner bearings (using the screaming eagle tool), I slid a single cam in each bearing and spun it around to check for binding. The front feels pretty good, but the rear seems like it's binding due to vertical play. Any idea if this goes away when it's actually installed with the plate, or do I need to purchase a new bearing and reinstall?
2. You reused your cams, which I will be doing as well. On your rear cam, did you pull the old thrust washer, o ring, and inner bearing race and install the new ones that come in the kit, or just use the old ones that were on there? If you did remove them, what did you use to get them off?
3. Do you need the cams to press the bearings into the support plate, or did you use a different method? If installed separately, how did you get the front cam into the bearing?
Thanks!
#36
Ok, I'm in the middle of this repair now and I have a few questions:
Thanks!
Thanks!
Now to your questions.
#1. You can't really tell if the inner cam bearing is in a bind by rotating the cam shaft in the bearing. If you used the tool the bearing should be seated properly and true in the bore but bearings can be defective out of the box. Feel inside the bearing and roll the rollers; do this to both bearings. The rollers should roll freely, if they don't, replace the bearing. If the rear is in a bind, you should be able to feel the difference between the front and the rear with you fingers.
#2. Glasspilot did not reuse his cams; he used his old rear cam to install the inner cam bearings for new cams.Why not use the new thrust washer and o-ring? Not sure what "inner cam bearing race" is referring to. The rear cam journals run in the inner cam bearing; no race.
#3. Cams cannot be installed one at a time; this is why you need the service manual. The inner cam chain has to be on the rear cam sprockets the dots on the sprockets aligned for proper timing.
Install the cam bearings into the cam plate; press them in with a hydraulic press or use the freezer/oven method. Freeze the cam bearings over night, heat the cam plate in the oven at about 300* for 15-20 minutes and the bearings will drop right in to the cam plate. Have a socket that matches the OD of the cam bearing so it can be tapped in if it doesn't drop in all the way and seat. You cannot press against the inner race of the outer cam bearings
#37
#1. If the rear is in a bind, you should be able to feel the difference between the front and the rear with you fingers.
#2. Why not use the new thrust washer and o-ring? Not sure what "inner cam bearing race" is referring to. The rear cam journals run in the inner cam bearing; no race.
#2. Because I haven't found a proper tool to take off the existing thrust washer. Sorry, I misused my terminology. It's the inner cam bearing race for the OUTER bearing. As in, it sits inside the rear bearing in the cam plate, and outside the rear cam journal in the cam plate.
#3. I understand this, and I do have the service manual. The question is: do you have to use the cams to install the outer cam bearings into the plate, or can they simply be put into a press and sent in flush. I'd love to do the oven/freezer method, but then I'd also have to remove my bypass spring and plunger. I have a friend with a press instead. This is only an issue because I have a limited time to use the press, but am not set on which cams I'm going to use. So, if I can press the outer bearings without a cam, that would be better than pressing with a cam, and potentially pulling that cam out, necessitating a new bearing to go with the new cam.
Thanks!
#38
#39
First, to be clear, I assume you are working on a '99-'06 model? You did not provide that information. '99s are funny, running change to the rear bearing from ball to roller mid year and from keyed outer cam journals to splined. From your description of the inner race of the rear outer rear cam journal, it sounds like you are working on a '99 up motor that was put together post the above referenced changes. So, to make sure we are on the same page, please confirm model year.
