Will this damage my bike?
Just installed a new Dragula 2:1 on my '14 SGS. My chosen tuner is about a 3 hour drive away. He said I should be fine riding the bike to him as long as I don't install the high flow A/C yet, and just bring it with me to be installed at his shop when I arrive. I've read some threads about running bikes too lean and doing damage to the engine. I would assume that, with the stock A/C still installed and the only change being how exhaust leaves the engine, the engine itself should remain relatively unchanged. Should I be ok?
will be fine.
for any damage to occur,the bike would run like sh!t.if its running OK,it`ll be fine.if its popping & cracking,theres a good chance of doing damage.check the plugs,they`ll tell the story of how its running (I assume your going to DOC`s)
Originally Posted by prodrag1320
(Post 12904194)
That Rush Wrath is not going to harm you prior to getting it tuned.
Scott |
Originally Posted by Hillsidecyclecom
(Post 12906342)
Scott |
When you see that tuner over in Mineola, tell him we said "Hi."
Scott |
Originally Posted by Hillsidecycle.com
(Post 12907024)
Scott |
Nice to have guys on here always willing to give advice.
jpalm
does that dragula 2 into 1 sound the same as a rush wrath ? |
© 2024 MH Sub I, LLC dba Internet Brands
