Primary chain housing drain plug leak
Received 3,222 Likes
Received 4,317 Likes
Pipe plugs are, as mentioned, a taper thread. 1/8-27 National Pipe Taper to be precise. They're meant to be used with some sort of sealant and tightened snug. Teflon tape or pipe seal works. I use Hylomar on my pipe plugs and snug them just beyond finger tight. Never had one leak or come loose. The Hylomar remains soft and sticky. Seals the threads, but is easy to remove when you want to.
