primary leak.
Old Jul 25, 2006 | 10:32 AM
skullandcircle's Avatar
skullandcircle
Default primary leak.
hi all,
changed the fluids in my 93 flstc last night, the primary was a little wet but i hadn't noticed any puddles under the bike. now it is leaking pretty good. my question is, how tight should I have tightened the plug? i didnt want to over tighten it but obviously I must not have gotten it tight enough.
thanks in advance.
Old Jul 25, 2006 | 10:39 AM
Softtail Bob's Avatar
Softtail Bob
Default RE: primary leak.
Did you use teflon tape? You need to wrap the plug with teflon or plumbers tape about three times then reinstall. This should fix the leaky drain plug.
Old Jul 25, 2006 | 10:42 AM
sleepneagle's Avatar
sleepneagle
do not use teflon tape. there is an O'ring that needs to be replaced on the drain plug.
Old Jul 25, 2006 | 10:57 AM
Softtail Bob
What year bike do you have? I have a 1998 and was told by my dealer and my mechanic that I needed to use teflon tape and have been with no problems. Did they switch to a o-ring at a certain year model????????
Old Jul 25, 2006 | 11:04 AM
Softtail Bob
Here is the schematic diagram for the primary on a 98 softtail and as you can see there is no o-ring for my year model or it would have a part number.
Softtail Bob
sorry for the double post.
Old Jul 25, 2006 | 11:10 AM
skullandcircle
ORIGINAL: sleepneagle
ahh, we did try teflon tape.. I wondered about an O ring this morning on my way in to work. I will swing by the dealership and get one on the way home. thanks for the replies.
Old Jul 25, 2006 | 11:14 AM
dert's Avatar
dert
On '93,there is no o ring on the drain screw .Correct,use a little teflon tape and leave about 1/8 inch of the screw visible .Make sure it went in straight as it can cross thread very easily...whole nother problem.
Old Jul 25, 2006 | 12:47 PM
skullandcircle
ORIGINAL: dert
thanks for the reply, looks like i will be trying it again tonight.
Old Jul 26, 2006 | 10:28 AM
skullandcircle
After looking at it again last night, the leak appears to be coming from the backside of the primary case and not from the plug. So now im dumbfounded as I have no clue what I am doing.
