Oil tank pressure?
Oil tank pressure?
Don't know if this is good or not but running it by you guys .
This only happened once. Went for a short ride and looked dn to see my oil filler cap had popped off and was sitting loosely on top of filler hole.
Rubber seal seems to be tight on cap but the pressure seems to be high..
No hot rodding at all when it happened.
Has not done it again but pressure seems high in the oil tank..??
Happened to a friend of mine. Turned out to be a broken piston ring causing excessive crankcase pressure to build. If tank pressure "seems high", it must be coming from somewhere. I'd perform a leak down test and see what it tells me.
Its happened to me a couple of times, but it's always been a shrunken filler plug. A new plug fixed it.
Received 4,317 Likes
Follow up on oil tank pressure and oil cap being pushed off. Not that anyone cares but awh well.
I ran 2 - 3/8 ID gas lines, one off each head breather. Ran them both up and over the heads and under main frame, then down and out by the rear swingarm and pointed out past rear tire. Seems to be doing well and the oil cap stays in place. Problem solved.
Oil tank pressure?
This sorta happened to me. When the plug pops out, does oil come with it? Mine was pumping primary oil in to the engine or the engine was sucking it out of the primary. If this is true check primary oil level to see if it is low. I have seen a couple of threads about this type of trouble.
Good Luck
Doug
Good Luck
Doug
