I think it would be easier to pull manifold. You might as well replace those seals while your at it and replace the Air Intake Temp Sensor if it has never been replaced as well. Can I ask why you are replacing injectors? Reason I ask is I have been around this forum for a while now and read it almost daily and I don't ever recall seeing a post about bad injectors on a MM system.
