What to do with the speed sensor on 98 RG?
I am in the process of upgrading my suspension and brakes on my 1998 Road Glide. I am adding ohlins cartridges and Ohlins rear shocks from Motorcycle Metal. I am also upgrading the fork sliders from an 06 and swingarm from an 07. With this change I will now be running 1" axels and going with brembo brakes
So my problem is what to do with the mechanical speed sensor? I though about machining down part of the axel to allow the speed sensor to keep working but it appears that sensor is wider than I tough and it use to rest inside the hub of the front wheel and the tab on the sensor rested on the brake rotor.
Please let me know of any ideas to correct my issue.
Thanks
Thanks
Thanks... I’ve been searching but I will double check brembo conversion search.
Received 4,317 Likes
Thanx for the correction Beemer...
