New Torrington bearing: Do I need to pack it with grease?
I'm going to replace pushrods, lifters and the inner cam bearing, I ordered a Torrington / timken / koyo. It came in a sealed plastic bag with some sort of clear grease already on it. Is that just to keep it from rusting or do these bearings come greased up and ready to install from the factory? If I need to pack it what grease are you supposed to use? Thank you
I've never had to do it but I seem to remember this came up not too long ago. I think what you need to do is clean all of that old grease out of the bearing then lube it with either assembly oil or motor oil. Do a little snooping around and see what you can find. The grease is likely in there to prevent rust. I like to clean bearings with kerosene as it is non corrosive.
carl
carl
Received 5,388 Likes
