Got ahead of myself
Got ahead of myself
I started working on the carb of my 92 Heritage Softail to update it with CV Performance parts and got ahead of myself. I assumed the carb hadn't been worked on and removed the only metal plug I saw that I thought covered the mixture screw was to install the EZ-Just mixture screw. The problem is that the carb had been worked on before and the plug over the mixture screw had already been removed. I removed this plug and have no idea how to fix this. Anyone Know if this is a problem and how to fix it?
Yeah, that's a problem. That plug (which covers an opening used to give access during initial manufacturing) needs to be there.
Shouldn't be a problem to tap in a new plug. I don't know if you can buy just one. Might see if CV Performance has them. I do know there are assortment kits out there. Do a google on "aluminum carburetor plug set".
Search the term "Welch plug" it might help you out IF you can't find the OEM part. If you already removed, then measure the plug and the bore so you can find the correct size, again IF you can't find the OEM plug. A little blue loctite (very little on the edge of the plug only) will help seal and hold the replacement in place. YD
Received 4,317 Likes
Hey Man (04-22-2019)
A properly cleaned and tuned CV is a great carb.
70's.
