Recommend me some slip-ons
Received 5,228 Likes
In the other thread about air cleaners, I mentioned that I have the K&N High Performance air cleaner element on the way. Well, I've been reading that Stage 1 basically calls for an improved air filter and slip-on mufflers. Or is this only referring to an entire new air cleaner system?
So if I replace my factory shotguns with a better slip-on in addition to the K&N high-flow filter, should I see a performance increase? And if so, what slip-ons would you suggest?
Windseeker (06-03-2019)
Thanks. What do you think about the performance question? Will good slip-ons in conjunction with the better air filter give any boost at all? I know there are tons of variables involved. My bike is bone stock mechanically as far as I know.
In your post you show a picture of a '94 Fatboy that does not have the stock shotgun exhaust I recognize.
Is that your bike?
If it is were the original equipment mufflers put on those exhaust pipes?
Another source for slip on mufflers is S&S but I'm sure they are pricey.
If you want to torture yourself you could modify a set of stock mufflers like I did but man, that turned into making the internals removable and drilling a LOT of holes.
I went through three or four drill bits. I had no idea what the result would be like and fortunately for me I was satisfied with them.
Is that your bike?
Is that your bike?
Is that your bike?
If u want to enhance the performance separate from the slip-ons, then you have the stages and cam's you may want to look at.
Hopefully that helps and I answered the question. I am really not good with the mechanical stuff.
Windseeker (06-04-2019)
Okay, so that is your bike.
Those pipes are usually referred to as staggered duals, not shotguns.
One type of shotgun pipes has the rear pipe higher up on the side of the bike.
That is the type that Harley used on the Fatboys.
There are more varieties of "shotgun" pipes as well and you can call your pipes anything you want.
But you may raise questioning looks from old guys like me that are familiar with more traditional shotgun style pipes.
Good luck finding mufflers you like.
Any insight on the power question, though? Or are slip-ons strictly for the sound?
I'll try and answer you performanced question, but my question to you is what are you trying to do? Are you just trying to make inexpensive bolt on mods to make the bike perform a little better?Depending on what slip on mufflers are used and also adding an upgraded air cleaner (Screaming Eagle/Arlen Ness, etc...) you can get some HP and tourque gains on an otherwise stock motor, but you are only looking to gain a few HP (looks like you already have the staggered dual slip ons). Re-jetting the carb and having a performance tune will also get you a couple more HP. Although the HP gain is modest with these changes, the bike will run much better. To really start getting a HP/torque that you can really feel on a fairly stock motor will require at the very least a mild cam change (stock 1994 HD cams are pretty pathetic performance wise) a good bolt in cam for an apploication like this is an Andrews EV13. Even more performance gains can then be made by raising compression, more aggressive cam, head work, but they will require getting into the motor and cost will go up quickly. Hope this helps.
Windseeker (06-05-2019)
Windseeker (06-06-2019)
