Need to replace crusty front wheel and upgrade brakes
I picked up this 1990 FXSTC (Softail Custom) from the original owner with 11K miles. I need to replace the tires as the both are about 17 years old!
The front wheel has some rust and I would like to just replace it. I know the bearings went from tapered to sealed and the size went from 3/4" to 1" to 25 mm.
If I find a set of wheels/tires from a later model, can the bearings be adapted to accommodate my axle? I really would like to put a breakout front wheel on it.
What about the brake rotor? What about the speedo drive?
Finally, I realize why I hated my old man's Harley's in the 80/90's - the single piston brakes suck. What are the most economical ways to provide more stopping power? it already has braided lines. I would like to upgrade to a 4 piston caliper on the front at least.
That's a sweet looking bike, right there. Well done!
I've never done a late-model wheel swap like you're proposing, but there are any number of threads from guys who did it. Nothing that can't be solved, but you've already pointed out some of the issues that will have to get sorted.
Personally, I'd rather stay with the tapered bearings. Much better, IMHO.
Wilwood GP310 caliper bolts on. Much better than the (really quite useless) stock unit. There are other 4-piston options, Performance Machine also sells a bolt on 6-piston unit that you might consider if you stick with the single disk.
Racepres (06-12-2019)
Received 4,317 Likes
rsscoggins. Is that a recent picture? Or. One that was taken when it was new? Super clean bike. I am a simple man. I would replace the tires and fluids and ride it like i stole it. But. I also know what it is like when you buy a new to me motorsikle. Nice. Have fun. Be safe.
We had to jump start it to get it to run but it does run. At a minimum it needs fluids changed, a battery and the brakes gone through - it doesn't stop well even thought the levers are firm. probably going to pull the carb and go through that as well just to make sure there are no surprises.
A few chrome pieces as worse for wear but they can be replaced over time - trans cover has a couple of spots, primary is pitting with a few bubbles. Front wheel has some rust because water collect in the groove on the lip.
I have been looking at Evo Softails for a while - and was trying to stay under $4K ideally but everything I looked at needed at TON of work to even be road worthy. This one will be road worthy will a little effort and then I can start doing some changes. This isn't my only bike - I have a newer Road King and the wife has an Electra Glide. This will be my run around town bike and something for my son to ride with us when he is home.
I would like to do an open primary...maybe a springer seat. And since I am 6'4", I need to address the ergonomics - extended controls and 16" apes will probably be the first thing to be honest.
Shoot me a pic - I would like to stay chrome on this older bike but lets see what they look like.
lyork
Stock Harley Take Offs
04-27-2015 08:04 AM
