evo cam bearing 101
evo cam bearing 101
OK , I graduated from a shovel to an evo thinking with the evo I wouldn't have near the problems and I could spend a winter on playing dress up instead of re-build. Now all I hear about is H.D put some crap *** cam bearing in my motor ( 1998 stock evo 1340 engine) so , and yes I know this has been the topic of several threads but I still want to ask fresh a couple questions so please don't flame me...
1) my bike has 10,000 miles and so far so good , does anybody have a rough guess as to percentage of engines that bearings went bad ? My buddy has 73,000 on his and no problems , I have 10 and am worried.
2) I am a little (OK a lot ) evo ignorant for the moment but I have the H.D. service manual , it looks like I'll have to pull the heads because the pushrods are non-adjustable to change the cam bearing. Is this correct ?
RE: evo cam bearing 101
ORIGINAL: zukeeper
2)Best to my knowledge you are correct.
Quick answers:
1) Can't intelligently answer about this one.
2) No. You can remove rocker covers, remove rocker arms, remove pushrods. Then you can remove points cover, gear case cover, cam, and then remove old cam bearing and install new cam bearing. A couple points:
You'll need to suspend the tappets either with paper clips or the cool magnetic tools (you'd need 2). Also, the George's garage can bearing installer works REALLY well as does Jims bearing puller.
ORIGINAL: winpitt
Quick answers:
Quick answers:
ORIGINAL: zukeeper
ORIGINAL: zukeeper
If you're going through all this work to replace the cam bearing you might as well install a better cam. Andrews EV3 is a good cam for the softails, but do your homework and select one that suits your riding style. A low restriction air cleaner, cam, pipes, SE or aftermarket ignition, and a re-worked CV carb will really make your EVO rock and roll.
Like HackD said, if you're going this far, change the cam. I'm running an EV27 from Andrews. I pressed the gear off my stock cam, pressed the gear off the new Andrews cam and swapped them. That way I didn't have to worry about gear lash or whinning. Something to think about. A new cam will really bring that baby alive. EV3 is a good cam too. You'll find a million opinions on cams
John
John
Cam bearing went out on my 96 Fatboy at 32,000 miles. I had the local wrench upgrade the cam to an Andrews 27 as well as upgrade the cam bearing. Bike runs stronger with new cam. Hopefully I will not have to do this again soon.
SD
[IMG]local://upfiles/9653/3B7B5C953ED44673B001AC83537E1D73.jpg[/IMG]
SD
A '98 should come with the Torrington bearing. At least that's what I'm hoping.
I'm swapping my cam ('98 FXDS) for a left over Andrews EV-27 from my last bike and I'm hoping when I open her up I'll find a Torrington.
Let me know what you find in there so I can plan ahead.
Thanks!
Thanks!
