Starter removal
Received 4,317 Likes
I am not familiar with the 1988 starter set-up but if you have the old system that has the solenoid fastened to the primary, then I'm thinking you can pull the motor off the reduction gear housing without opening up the primary.
That would be you are removing the starter motor only, not the reduction gear housing.
If you do wind up pulling the primary cover, stop and disconnect the positive cable from the battery. If you move the starter linkage much inside the primary you might energize the starter motor (if it is still installed on the bike) and then you may find your fingers in a meat grinder.
Years ago when the bike was new to me, and I was in the primary messing around, I did just that. I didn't get chewed up, but scared the hell out of me and left a big impression. Won't do that again!
Received 3,222 Likes
bluharley... '84-'88 FLT/FXR models do not require you to remove the jackshaft in order to remove the starter motor and housing. Jackshaft removel prerequisite started in '89
And make sure to disconnect the pos lead on the battery so that you do not end up activiating anything.
And I assume you are talking about the bike in your sig pic...1988 FLTC
Yea, my '88 Tour Glide. I remember back some time ago, I think I pulled the starter for unknown reasons (I played a lot when i got it), and I think I remember pulling it without taking the outer primary off, but I think I also remember having a hell of a time getting it back in the hole. Maybe I'm thinking about someone else.
Yeah it can be a bit of a pain to get the end of the starter motor gear aligned with the drive gear in the housing and then rotate it a bit to align the holes for the long through bolts.
And if you think about it, take pics as you go so that it becomes a "tech-tip" for the next one in line who has the same question. They hit the "search" button with the question and yours shows up and gives them first-hand info.
All OK except the book says to remove both battery cables and always remove the negative first. I have always just removed the negative cable when working on electrical stuff and cover the battery terminal with something unless you are sure the cable cannot make contact with the battery terminal.
