Awe, Hell.....
Old 10-30-2014, 10:54 AM
Tailbreaker's Avatar
Tailbreaker
Tailbreaker is offline
Originally Posted by NickD
The big thing with a pawl spring breaking is whether or not it went through the gears. I had one fail coming off the freeway while I was downshifting. Same as you, same noise, and a floppy shift lever. Here's mine . . . (If you see multiple bits of spring, like below, or bits that look chewed up, that means the spring bits hit the gears. You have to check every tooth of every gear to be sure.)
I'm not seeing any damage to the gears but I won't be able to fully inspect them until I remove them from the case.
Old 10-30-2014, 01:39 PM
zimm's Avatar
zimm
zimm is offline
Would this be the time to install a 6 speed gearset?
Old 10-30-2014, 01:45 PM
Tailbreaker
actually I put my other bike up for sale when I thought I did major damage. It it sold, I was going to buy a Baker 6 in a 5
Old 10-30-2014, 03:47 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,319 Likes on 1,947 Posts
FWIW Baker recommends the DD6 for the 80" EVO.
Old 11-19-2014, 08:41 PM
Tailbreaker
Just to update this thread, I had a broken shift pawl spring and a damaged countershaft gear. Following Spanners advice, I was able to completely disassemble the trans up to the main shaft without removing the primary or starter. Although, the time spent trying to get that little shift shaft circlip off and back on again, I probably could have removed and reinstalled the primary a couple of times. I installed a Baker anti over shift pawl that has a better designed spring and I found a NOS Harley countershaft gear on Ebay for $20.00. I just need to finish torquing the external bolts down, add fluid and replace the oil tank and exhaust. Thank goodness there was no real damage.
Old 11-19-2014, 09:28 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Thanks for the update! You dun good.
Old 11-19-2014, 09:38 PM
Rhino-1's Avatar
Rhino-1
Rhino-1 is offline
Love it when it when a plan comes together! lol! What would we do without folks like Spanner (and all the rest of you!) on here?
Old 11-19-2014, 09:44 PM
Beemervet's Avatar
Beemervet
Go to the touring forum!
Old 11-19-2014, 10:08 PM
texashillcountry
Dirt don't hurt
For what?????????
Mind numbing idiocy?????
Old 11-19-2014, 10:51 PM
Beemervet's Avatar
Beemervet
What would we do?
Just trying to help here.
Quick Reply: Awe, Hell.....
