Help with my 93 fxrs plzzzzz!!!!
Old 09-16-2016, 01:04 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,055 Likes on 1,511 Posts
Originally Posted by dports70
Electrical problem suck, so many possibilities, and they are all time consuming
And I find it generally simple...If [Big word] it is in front of me.. and it hasn't been ****ered with by unknowing persons...
Old 09-16-2016, 01:22 PM
fxrs's Avatar
fxrs
fxrs is offline
Yes I dread electrical issues.
I will add that i did check the breakers from both from the neg side of the bat and from the frame and they are hot
I want to check the electronic ignition module. Anyone know how to check that to show its still good
Old 09-16-2016, 03:23 PM
FlamedFXR's Avatar
FlamedFXR
FlamedFXR is offline
Received 1,529 Likes on 652 Posts
Check the lead that runs from your voltage regulator to the 30 amp breaker. It snakes around through the frame. If it has a rub somewhere it will keep the breaker tripped.
Old 09-16-2016, 03:57 PM
brad75raiders's Avatar
brad75raiders
brad75raiders is offline
Mine was a negative battery cable that wiggled loose melting the battery post as well as the middle of the battery cable. I couldn't tell because the cable has a black insulation on it. As soon as I pulled the battery the negative cable broke in half.....
Old 09-16-2016, 04:18 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
Originally Posted by fxrs
Yes I have been working with my test light and the schematic for days on and off when I can. neg test lead to the bat and positive lead to both sides off all 3 breakers and its hot on both sides.
You have 4 breakers on that bike.
Hunt down the 4th and check that one too.
Old 09-16-2016, 04:59 PM
01fxdxt's Avatar
01fxdxt
01fxdxt is offline
Replace the cable that broke.It very well could be internally corroded and has high resistance.
Old 09-17-2016, 09:05 AM
Racepres's Avatar
Racepres
Racepres is offline
I cheat...Put in a different one and see...
Old 09-19-2016, 09:10 PM
fxrs's Avatar
fxrs
fxrs is offline
Looks like it's the ignition module. Tested it in a buddies bike and it did not work. Have one coming should see it by Friday. Then hopefully my problems are solved unless there's something else.
i'll let you all know. Thanks for all the help
dports70 (09-19-2016)
Old 09-19-2016, 10:02 PM
FlamedFXR's Avatar
FlamedFXR
Then check the pickup in the nosecone. If its bad and took out ICM it may take out the new one.
Old 09-20-2016, 05:41 AM
fxrs's Avatar
fxrs
fxrs is offline
Ok thanks.
How do i go about testing the pickup to rule out it smoking my new parts ?
Thanks again everyone
Quick Reply: Help with my 93 fxrs plzzzzz!!!!
