Rear caliper brake line fitting
My issue is figuring out what to do with the brake line hole - looks too small for a banjo bolt and the fitting that's there doesn't seem right.
http://partsfinder.onlinemicrofiche....=28&c=0&d=2000 FXST SOFTAILŽ STD (BH) BRAKE - REAR BRAKE CALIPER ASSEMBLY
It looks like 2000 was the first year of the 4 piston caliper on the rear for softails.
The fluid that was in there was yellow, so definitely not DOT 5 - not sure if it was 3 or 4.
The brake line has a threaded end on it that connects to the fitting in the photo that I posted originally. My concern is it sealing to the caliper.
14GuineaPig - thanks for that. This clears up at least one thing - the bleeder screw is in the correct hole. Strangely the diagram does not show a part for the brake line connection.
Here's the diagram showing the brake line
Received 4,338 Likes
The best way to tell is put some on your fingers and rub them together.
If your fingers slide against each other easily then it's dot 5 if they don't it isn't.
I think I have an original 84 set up if you need it..they are hard to come by...only made in 84-85.
*Edit* I looked at the pics in your other post....it appears your swing arm has been modified.
