I really lost myself this weekend
  #391
Old 02-13-2019, 02:54 AM
splattttttt's Avatar
splattttttt
splattttttt is offline
Matt, that is xactly why I like to know the reason for needing to know what your head temps are telling you.
I imagine that your goal is to keep temps as low as necessary to maintaing an efficient system.
But which part of it exactly?
Or are there many other factors you are after other than over all efficiency?
I know that avoiding overhating it will preserve the life of your motor. But is there one specific matter or issue you are trying to keep under control?
  #392
Old 02-13-2019, 09:06 AM
Schex's Avatar
Schex
Schex is online now
Received 6,877 Likes on 1,786 Posts
I think Matt had some past scuffing issues he's trying to avoid on his recent build.
In my case, I'll take a look at HT just because I already have the gauge, and 5 minutes to rig, just another evaluation tool., what I don't want to see is a big difference between front and rear cyl's
I richened the carb after a rear blown head gasket a couple years ago, but it was really an under torque issue a few S&S engines had a while back, MPG's did suffer.
It's time to go through the carb, so I'm going to retune, then the temporary rigged HT and AFR meters get removed.
  #393
Old 02-13-2019, 09:54 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,974 Likes on 3,394 Posts
Matt's had back luck with a couple of builds that did show hi heat concerns... Knowing that, he's trying to keep his temps down to not ruin another build... If timing, fuel and compression are on and an AFR meter to confirm, I don't see the need to go as far as he is.... And for that An IR meter is fine... But to each his own..
  #394
Old 02-13-2019, 01:09 PM
Mattbastard's Avatar
Mattbastard
Mattbastard is offline
Received 1,408 Likes on 864 Posts
All correct. This is round 3 on this motor and I wanna make damn sure things dont get out of hand, temp wise.
The irony is that even though I’m monitoring just about everything I possibly can in real time I still have no idea where the official temp threshold is. Just suggestions and conjecture from others where I need to grow concerned. At least it’s a guide, but it would be nice to know for certain what blew up my last two attempts at a 107” Evo.
I swear to god if this one pops I’m gonna buy the cheapest stock Evo I can find and trade the bike in for a newer Twin Cam based Road King.
  #395
Old 02-13-2019, 02:18 PM
JakeC7R's Avatar
JakeC7R
JakeC7R is offline
Don't worry, I got you covered just in case....
https://www.hdforums.com/forum/motor...tail-flst.html
  #396
Old 02-13-2019, 02:53 PM
98hotrodfatboy
Matt, what are the entire build specs? I lost track.... What carb, ignition, Pistons, cylinder head including combustion chamber size, intake port mods, do you know what CFM the heads are flowing. Pipes... If you don't mind me asking...
  #397
Old 02-13-2019, 04:03 PM
splattttttt
Following your build since the biggining. You have every right to protect your self from destroying another build. Or you can ride like an ole lady. Problem solved
Joking aside tho, I’m beginning to wonder if the MoCo base Evo or twink has wat it takes to get big.
Bigger than 110.
Think about what they did to get to 103. 110 and I guess they can sell you a 114 in twink form.
Now they have the M8. From what I read. They’re a crap shoot.
  #398
Old 02-13-2019, 06:29 PM
bagga's Avatar
bagga
bagga is offline
do you know anyone else with an evo? stock or otherwise? if you do, put all the head temp stuff on that just to get an idea what is normal. like i said my stock evo runs about 350 but i don't know how accurate the HD gauge is.
  #399
Old 02-13-2019, 09:58 PM
Mattbastard
S&S case w/ 4 5/8" stroker crank, Axtell 3 13/16" flat top pistons and cast iron cylinders, Hammer Performance Stage 4 heads at 91cc, CV40 carb, S&S 520 cam, Ultima ignition 58-644 w/ wasted spark coil, chopped Thunderheader 2-1. Eventually I'm going back to the 585 cam and maybe a Super E but I'll need to build up the combustion chambers a bit with some welding. Originally I went with 30 degree domed pistons and the heads are machined for it. Now that I'm back down to flat tops I've got a lot of extra combustion chamber, but the actual CR right now is a very accurate and very streetable 9.5:1. This is great for break in, but eventually I wanna get back into my 585 cam so my plan is to build up and reshape the outer fringes of the combustion chamber with some TIG beads, then some grinding and milling to get me around 85cc (and 10:1)
Yes actually, I helped my dad rebuild a 1996 Dyna. This is a great idea! Thanks.
  #400
Old 02-13-2019, 10:00 PM
Mattbastard
Nice bike but I meant Evo engine.
That's the cleanest 89 I've ever seen tho.
Quick Reply: I really lost myself this weekend
