95 Road King Front Air Ride
Old 12-16-2018, 11:53 AM
AlCherry's Avatar
AlCherry
AlCherry is offline
Default 95 Road King Front Air Ride
Can all the plumbing be removed and run as a conventional front end? I'm looking at the diagrams of that front end and I don't see any difference other than external hoses and different caps. Correct me if I'm wrong.
Old 12-16-2018, 01:53 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,708 Likes on 1,161 Posts
I took it off my 97 EG. Did a rebuild on the forks and replaced the springs at the same time. Found plugs to fit in the caps where the air lines went and reused the caps.
WP
AlCherry (12-16-2018)
Old 12-17-2018, 04:54 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Wink
Yes you can, however be aware that compressed air is a spring, so running some air pressure effectively adds an extra spring to your forks. Remove all the air system and your forks are likely to be too soft, sag more than they should and give you a poor ride. The least you should do IMHO is change to a set of single-rate springs, matched to your weight. Race Tech sell them and also provide a chart on their website so you can work out which springs to buy. You could also consider getting Ricor Intiminators, to provide improved damping. Race Tech sell Emulators, so it is tempting to buy them, but whereas I have been happy with Intiminators I haven't had success with Emulators and can't recommend them.
Old 12-17-2018, 07:57 AM
splattttttt's Avatar
splattttttt
splattttttt is offline
The air is a good compression system and takes a lot off streenoff the springs. Allowinh them to last much longer.
only problem with any air system though, is lack of gauges. Hard to tell hiw much pressure you’re running with out a gauge
Testing pressure with a tire pressure readining is fine. Buy we use so ittle air that by the time we have a reading, all the air is out of the system
Old 12-17-2018, 08:08 AM
86glider's Avatar
86glider
86glider is offline
I installed a tee fitting on my 86 w/small 30# gauge..
Old 12-17-2018, 11:16 AM
splattttttt
Love to see a picture. And if it was a simple install? Thanks
HarleyX89
01-09-2017 11:42 AM
larry harding
Air Suspensions
01-26-2015 01:51 AM
bigirn
07-08-2012 03:54 AM
Puzzled
04-29-2007 12:35 AM
1sportytrike
02-24-2007 12:44 PM
Quick Reply: 95 Road King Front Air Ride
