Motor maybe gone
1 Attachment(s)
Had a whirr, quietted down, and then the sounds of a quarter in a tumble dryer.
96 EFI Stock-ish EVO. FullSac only non stock item (I think). I have pulled the primary, Plugs out, hand turned and scraping noise in front cylinder near TDC. Local HD Service does not reccomend REMAN for several reasons. I am looking for a Rebuild Indy in the Northern VA area or a good source for new or reman 80" EFI ready to runs. Touring model Chrome and Black. Any help? Much appreciated. |
check with chicago hd. they always have good deals on bn replacement engines. other than that, if you wanted to ship your current engine out, there is a great harley shop in central new york called hilltop motorcycle and machine located in munnsville. i have never heard any bad work come from them. they are noted for being able to make a shovel run like no other
There are many options for that set up, the reman engines from hd are so -so. Have you found out what is wrong with yours yet? Maybe it can be repaired for less than a new engine. We do offer outright EVO & Shovel HD engines with your core as exchange. The one that is currently being finished up is 80 inch, SE heads, woods 6 cam, cp forged pistons, compression 9.7.1
How about the remanufacture through the MOCO . They say no to a rebuild but try it that way.
Originally Posted by HDWRENCH
(Post 3790893)
Thanks. flstf93, I'll scope out Hilltop as well. Price |
Originally Posted by FLGEEZ
(Post 3793076)
HDWRENCH, Sent ya a PM.
Thanks. flstf93, I'll scope out Hilltop as well. Price Hillside Motorcycle Machine 5225 South Main Street Munnsville, NY 13409 phone: (315)495-6650 |
FWIW, I recently considered replacing my engine (87 Heritage) Could have snagged a 113 or 120" Ultima on Flea Bay for well under 4K delivered. Decided to run my current motor a bit longer as I just dropped a 6 speed in and need to build up $$$.
Fell on the knife and took the Road Sofa to the Local. Lost the cam bearing and created a bit of havoc.
New cam, bearings, cylinders, piston, rings and maybe an oil pump. Without a flywheel or crank problem and no headwork....approximately $3000.00. 50/50 parts and labor. Gonna put a Torrington bearing in this time. INA no way. I couln not find a close-in rebuilder that anyone would reccomend or a straight 80" EFI . motor |
for $4000 I put in a 127 ultima fully polished bolted right in to my 1995 FLSTN took about 4 hours to put it in. They also make a great touring motor the 120 which is 4.25 bore 4.25 stroke. Not worth fixing my 110 for that money.
Don't think I want a Power Hog for a touring motor. My Black and Chrome EFI wouldn't look quite right with a Shiny Thing.
Good luck with your Softie. |
© 2024 MH Sub I, LLC dba Internet Brands
