How do I remove the body of my radio 1986 Elec. glide classic
Old 03-13-2012, 11:36 AM
watindes's Avatar
watindes
watindes is offline
Default How do I remove the body of my radio 1986 Elec. glide classic
Hey,
I want to send my radio off for repair, I pulled the screws out of the facia of the batwing and the front face came off the radio. It looks like it has a board that connects it with the body of the radio. All the tape deck and body is deep in there and I was wondering how to get to it, do I have to remove a section of the fairing? I thought if I unscrewed those scres and undid some clips (like a car stereo) it would come out but I was wrong.
Help?
Jesse
Old 03-13-2012, 11:49 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,715 Likes on 1,347 Posts
It's probably going to have to come out from inside the faring, if it's original. There were 2 holes in a metal plate behind the face, like the old style **** radios would mount in.
Old 03-13-2012, 02:06 PM
miacycles's Avatar
miacycles
miacycles is offline
Try taking the headlight out, I know there are some plugs and a bolt or two in the back of the radio, plus the antenna. Hope this helps.
Old 03-13-2012, 02:07 PM
watindes's Avatar
watindes
watindes is offline
Yep, thats exactly what it looks like, **** style.
Jesse
Old 03-13-2012, 03:45 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Yeah, I cut that plate out on mine to fit a conventional (modern) DIN unit in.
Old 03-14-2012, 03:03 AM
Muganic's Avatar
Muganic
Muganic is offline
Default Radio removal
Hi there,
I have an 86 Electra Glide Classic that I have pulled the radio out of a couple of times. Remove the headlight and then the bat wing fairing, then a brace above the radio then the radio. Tip there are 4 x 7/16" nyloc nuts inside the bat wing to loosen before you can remove the fairing - a ratcheting ring/open end spanner here saves a lot of grief. Sorry if the tool description is different to what you are used to but I hope you get the idea. The first time I took off the fairing I used an open end spanner - one nut flat at a time - not fun
Cheers
Bill
Old 03-14-2012, 07:29 AM
Summers420us's Avatar
Summers420us
Summers420us is offline
Can you post a pic of the radio? Curious if it is the same as my 87 radio... If it is, I am curious who you have that will be repairing it.
80bobber
Audio Systems
08-05-2013 10:01 AM
jkeeton81
02-05-2013 02:51 PM
gillie64
01-02-2010 11:34 PM
cantdecide
09-04-2006 02:57 PM
Quick Reply: How do I remove the body of my radio 1986 Elec. glide classic
