EVO rear cylinder stops firing
Whose ignition are you running in the nosecone?
Several models, including Crane failed a lot in the high heat region inside the nosecone.
I'm going to say you need to reinsert the original designed system with the optic sensor timing trigger, and use a frame mounted aftermarket ignition module.
There should be a location for a standard ignition module, often they are located in the steering neck region, and some under the seat.
The only other possibility is that when heated up either some of the main ignition wiring is shorting to the frame, or you have a conductor broken inside of it's insulator. When this heats up the insulation stretches and the wire stops making contact.
You can swap both ends of the wires to isolate a wire or swap the plugs to isolate a plug, and swap primary wires and one end of the secondary to isolate a single fire coil.
It's really a pain the issues you get with a bad ignition module. Glad you were able to get it fixed.
Not all manufacturers units went bad in the nosecone. Whose ignition did you have? Whose did you put back in?
I wound up replacing the entire ignition system before I replaced the module and it fixed mine. Now I know my system isn't all 26 year old parts ... lol
