Hayden oil fix, pigtails, or James metal base gasket
Old 01-22-2013, 06:07 AM
busterman2's Avatar
busterman2
busterman2 is offline
Default Hayden oil fix, pigtails, or James metal base gasket
I am doing top end on my stock 1991 FLT and will be fixing typical rear cylinder base leak while apart. Can anyone tell me if the James metal base gasket will succesfully fix this leak or can it only be fixed with a Hayden oil fix or pigtails. Reason I am asking is, I have read several posts where Hayden oil fix was used and after around 100 milesito trip, oil backed up into rocker cover and leaking at rocker due to slow down of oil passing through to motor case. It is reasonable that the Hayden or pigtails kit would decrease the size of the return hole to the cases. I have seen several people say that the James metal base gaskets alone witll fix the leak. Any ideas. Thanks!!
Old 01-22-2013, 06:53 AM
traildog's Avatar
traildog
traildog is offline
MY bike has had pigtails for longer than I've owned her. I just did the base gaskets and could see no evidence that oil backed up in the rocker boxes.
I used Cometic gaskets to do the rebuild.
I have a Hayden Oil fix for sale (didn't know I had the pigtails until I took it apart) and I'll let it go cheap in case you decide to use one.
Good luck!
Old 01-22-2013, 07:47 AM
jsbridgew's Avatar
jsbridgew
jsbridgew is offline
my personal experience:
I've used stock, james, and cometic base gaskets and none of them worked to fix the rear cylinder seep.
I got the Hayden oil fix, installed the pigtails and new stock gaskets, and it fixed it.
Old 01-22-2013, 08:08 AM
traildog's Avatar
traildog
traildog is offline
Hayden and pigtails? Both?
The pigtails on my bike are tapped and threaded into the jug. I don't think Haydens install that way.
Old 01-22-2013, 08:55 AM
jsbridgew's Avatar
jsbridgew
my fault, i misspoke... i used the haydens, tapped in
Old 01-22-2013, 05:23 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,320 Likes on 5,423 Posts
I installed the James metal gaskets 12 years ago...hasn't leaked at all
Old 01-22-2013, 06:34 PM
busterman2's Avatar
busterman2
I am confused what to do. I had read several past comments that after a long ride, the Hayden or the pigtails could make oil back up in rocker boxes and oil would leak from rocker boxes. Can anyone tell me who I could order the pigtails from? Thanks,
machinehed's Avatar
machinehed
machinehed is offline
Newbie question ... am familiar with the Haydon oil fix but what are " pig tails " .?
Old 01-22-2013, 06:48 PM
traildog's Avatar
traildog
traildog is offline
Attached Thumbnails Hayden oil fix, pigtails, or James metal base gasket-59-8050.jpg
Old 01-22-2013, 07:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,506 Likes on 4,617 Posts
Have your machinist flatten the bottom surface of the cylinder.
Quick Reply: Hayden oil fix, pigtails, or James metal base gasket
