Bagger Nation Cult 45
I installed the new Bagger Nation Cult 45 slip ons. I love the sound, but it is not quite loud enough. I am unable to remove the baffle myself to modify it. It just doesn't want to come out, and I have tried using CRC, rubber mallet, and WD40. I plan on taking it to a mechanic, but I wanted to see if anyone else has any experience with these pipes. Is there insulation that can be removed? Has anyone been able to remove the baffles? Any help or advice would be appreciated. Thanks in advance.
So I assume no one has experience with these slip ons, but I wanted to give an update which leads to another question.
I had some luck with removing the baffles from the slip ons. There was no insulation. It's significantly louder, but there is a lot of "gurgling" on deceleration which is annoying. I also know it will probably damage my engine in the long run because of the lack of back pressure. I went ahead and ordered Big City Thunder baffles. Will these cure the annoying deceleration sound? I am running Khrome Werks 2 into 2 header system, so the baffles they sent me are quite small and have a different look than others I have ordered in the past. Will my engine be safe from damage if I leave out my stock baffles and just run the BCT baffles? If I put back the stock baffles along with the BCT baffles, will I be back to square one with the quiet sound, or will be louder? Sorry for all the questions, but I have an OCD problem when it comes to my exhaust. Please offer some feedback if you have any. Thanks |
Originally Posted by StugotSOA
(Post 16292688)
I e been looking at these. I have V&H turndowns now and have been curious how they sound compared to them. What are you comparing them to say they’re not loud enough? Thanks.
(Post 16292688)
© 2024 MH Sub I, LLC dba Internet Brands
