Bassani 2 into 1 question..
Both headpipes and mufflers change depending on the system you choose. Also, pay attention to the year range each system fits. Probably a good idea to call Bassani and ask them to explain the nuances of the systems.
For example, the B1 FLH-777 says it's for engines over 130 hp, while the B1 FLH-767 is for engines producing over 120 hp.
- 2-into-1 equal-length headers
- Stepped 1 3/4" to 1 7/8" into 2" headpipes
- Utilizes an advanced inner collector for maximum performance
- 4" Straight muffler
- Stepped 1 3/4" to 1 7/8" to 2" headpipes
- Megaphone muffler
- Stepped 1-3/4" to 1-7/8" headpipes
- Megaphone muffler
1 2 many (08-11-2018)
107 outlaw
well I did a FM 107 outlaw build. On my 15 rgs took the bike to get dyno tuned and the bike had some crazy reversion. It sputters at 2700 and very little at 4000 rpm. This was only happening when we got on the throttle hard for the dyno pulls. Well I pulled the 19" baffle out. And installed a smaller baffle in and the bike improves instantly. I think its choking the engine up . I triple checked my end at least the mechanical portion timing,compression, leaks.and push rods. All checked good.
Br125 (08-14-2018)
I think the higher output 107 (120 hp) dont do well with the b4 RR. My lesson. Now I gotta spend more money for a new pipe.
