95" ST 2 BIG BORE RELIABLE?
RE: 95" ST 2 BIG BORE RELIABLE?
ORIGINAL: TCSTD
Some of the Hi dollar and many others along with the se bikes come with synthetic oil from the factory, It is no problem with break in whatsoever. Just tolerates more heat before breakdown.
Here's just a few that come with syn oil in them from the factory
Aston Martin
Bentley Amage and Bentley GT
Cadillac CTS, XLR, SRX and STS
Chevrolet Corvette
Dodge Viper
Mercedes-Benz AMG vehicles
Mercedes SLR
Mitsubishi EVO
Pontiac GTO
All Porsche vehicles
Aston Martin
Chevrolet Corvette
Dodge Viper
Mercedes SLR
Mitsubishi EVO
Pontiac GTO
All I know is that NONE of the engine builder's who do it for a living (at least none that I've ever used or talked to) ever recommend using synthetic in a newly REBUILT engine.
ORIGINAL: FBFletch
And I know quite a few Porsche owners who have sworn off synthetic, myself included. Especially true for guys who track their cars. Even with the heaviest weight synthetic, it thins too much at temperature causing oil pressures to drop dangerously low at the track.
ORIGINAL: TCSTD
Aston Martin
Chevrolet Corvette
Dodge Viper
Mercedes SLR
Mitsubishi EVO
Pontiac GTO
Aston Martin
Chevrolet Corvette
Dodge Viper
Mercedes SLR
Mitsubishi EVO
Pontiac GTO
Many engine builders come from old roots and old ways of thinking, but I can put down a list of builders though who also use straight synth from day one on new builds (race or street), so where does this leave the whole topic? Apples to oranges? Liquid cooled to air cooled? Auto to bike? I know I have never had a single issue of ring seal, or engine breakin that was in anyway detrimental by using synthetic. I have seen fried rings though from using dino oil upon initial breakin on more than one occasion on a vtwin air cooled engine.
ORIGINAL: MegaHDman
If your at the race track, you should probably be using a straight weight oil then, not a multi weight oil as your post suggest. If oil "thins" at running temp where its detrimental to the engine or its performance, you probably need to change weight.
Apples to orange? Liquid cooled to air cooled? I don't think so. It's only been recently that Porsche was forced to go to water cooling on the 993s and 996s. And, it won't be long before you see the last new air cooled Harley Davidson. Even among the Porsche air-cooled crowd there's a long running debate over syn versus dino. Bottom line is, whether it's a car engine or bike engine it still needs lubrication. And, as long as there's dino oil available, the debate over dino versus synthetic will continue.
ORIGINAL: MegaHDman
20-50w as suggested will act as a 20 weight at running temperature, so thats why you probably think its too thin if 30 straight weight is preferred in your application.
I think that's backwards. 20W-50 means 20(Winter) when cold, 50 when hot.
>>Multi-weight oils (such as 10W-30) are a new invention made possible by adding polymers to oil. The polymers allow the oil to have different weights at different temperatures. The first number indicates the viscosity of the oil at a cold temperature, while the second number indicates the viscosity at operating temperature. This page from the Sci.Electronics.Repair FAQ offers the following very interesting description of how the polymers work:
At cold temperatures, the polymers are coiled up and allow the oil to flow as their low numbers indicate. As the oil warms up, the polymers begin to unwind into long chains that prevent the oil from thinning as much as it normally would. The result is that at 100 degrees C, the oil has thinned only as much as the higher viscosity number indicates. Another way of looking at multi-vis oils is to think of a 20W-50 as a 20 weight oil that will not thin more than a 50 weight would when hot. <<
http://auto.howstuffworks.com/question164.htm
Yep, your right on that. I did get it backwards, but at running temp the oil is supposed to act as a 50 weight and not break down to anything less than 20 weight. The polymers are what make the 20w act like a thicker oil. Polymers due break down and as they do the oil is not supposed to thin past 20w.
In heavy duty racing applications using a thicker straight weight oil is still a better idea, straight 50 or 60 weight would be ideal, and that bears more importance than the synthetic label.
I just have to ask one more question and then I'll let this one go. If dino oil is so bad for motorcycle engines, as some here have implied, can someone explain to me why all Harley Davidsons (with the exception of the Screaming Eagles), come from the factory with dino oil? Perhaps it's because HD wants the engines to tear up so their customers have to bring them in sooner for rebuilds. Maybe we should all bring a class action law suit against HD for putting dino oil in our bikes at the factory.
ORIGINAL: FBFletch
ORIGINAL: MegaHDman
$$$ Cost.
ORIGINAL: FBFletch
3.5 quarts of HD Dino oil at $3.95/quart = $13.83
3.5 quarts of Screaming Eagle Synthetic at $8.95/quart = $35.35
So basically, HD was willing to risk a $4000 engine (minimum) over $21.52 worth of oil. You're right. It all makes sense to me now.
ORIGINAL: FBFletch
Let's see:
ORIGINAL: MegaHDman
$$$ Cost.
ORIGINAL: FBFletch
