shovelhead + s&s carb = what jet?
A buddy just picked up a VERY used 83 Lowrider Shovelhead. It has an S&\\;S carb from a Sportster.........Long story.
Anyway, it obviously doesn't run right and lean bogs at anything over 1/2 throttle., but it starts and idles fine.
Does anyone know what sized jets (approximately) we should start with to get things in the ballpark?......I have no idea what make of pipes are on the bike.
Thanks.
Thanks.
RE: shovelhead + s&s carb = what jet?
If \\;the engine is \\;close to stock those are the numbers from S&\\;S for sure and a good starting point. But really check closely for air leaks, Shovels are really **** to this leak. Also not sure about his comment about the carb from a Sportster,  \\; \\;
