True Duals Gone!!!
True Duals Gone!!!
Just got back from Eureka Springs AR. on Sunday \\; Bike ran great but I was disipointed in the lack of TQ when pulling the hills 2 up. When the Ole Lady and I got home I pulled the Fullsac conversion and re installed the factory Y pipe and re installed my V&\\;H Basic Slipons. \\; Man what a diffence in low end TQ and \\;it gets up to speed way faster than with the true duals and 6th gear is more pleasurable at lower speeds. \\; I used to not shift into 6th untill around 70 to 75 mph, now 65mph and I feel no lugging. \\; I guess the addition to re introducing backpreasure into the motor makes the engine feel tighter. \\; I did notice a little loss of top end but who cruises at that speed for extend pierods? \\; Another benifit is I gained back about 6 to 7 MPG.  \\;No more vibration whatsoever \\;at any rpm or gear, idle is way smoother, \\;Db's are down by atleast 50% \\;and my bike is more refined and \\;responsive. \\;  \\; After 5 hours of listening to the true duals I was getting shell shock. \\; I have a set of RJ Original heat shields and I swear the heat output is less with the Y pipe and the factory heat shields installed. \\; The Fullsac reuses the factory shields but on the rear pipe you only get about 1/4 to 1/3 coverage. \\; I believe with the exposed pipe, more heat is radiated and the RJ's funnel air in and blow direct heat out. \\; Anyway my bike is a pure joy now with just V&\\;H Basic slipons, PCIII, SE/AC, and IDS. \\;
RE: True Duals Gone!!!
We have also witnessed great power from the OEM headpipes, combined with certain mufflers.
Supertrapp slip-ons are about the best.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
 \\;At what speed or rpms did you notice vibration with you duals? Ever since I put Kerkers on my stock head pipes I have noticed a vibration at different highway speeds. I was told it was the air bag baffles opening. I hate it. Do you Like the sound of your V&\\;H slip ons?
