Cam opinions for a light softail...
Well, I opened it up today and the inner tensioner is ready to blow at 23K easy miles. I was nearly ready to upgrade to gear drive cams (even though I'm recovering from an indiscretion with Ride wright last week in the form a of anew 21" 80 spoker). I researched previous posts and most replies seem to be from you guys running baggers. I'm considering dropping in either the Andrews 26 or 37G cams. Any opinions on how they might run in a light softail with an otherwise stock motor aside from a mikuni 42, open stack and straight 1 3/4" drags? I might do the top up to 95" with mild headwork in the future so room to grow would be nice also. I usually ride solo and am pretty light at 160. I'm concerned with torque up to 4.5 to 5 grand and am looking to get a nice cammed up sound. Thanks for the input...
Jess
Jess
RE: Cam opinions for a light softail...
well, you will get a lot of recomendations here! I would get the head work now and get the cams to match.
If not then the Andrews 37s are good and have a good rep. the Woods 6 has a great rep too, but are around 100$ more. the Head-Quarters cams are a great choice but work best as a package and they only offer 1 bolt in cam the 0034 or TC 500. all these cams work good with a 95 or 103.
There are better choices of cams w/headwork, but with stock heads your description sounds like a perfect call for the Andrews 26's...&\\; they'll get even better when you go 95". The only prob you may have is keeping the bugs outta your teeth &\\; rubber on your rear tire.
VicW.
ORIGINAL: Sleeps In Trees
There are better choices of cams w/headwork, but with stock heads your description sounds like a perfect call for the Andrews 26's...&\\\\\\; they'll get even better when you go 95". The only prob you may have is keeping the bugs outta your teeth &\\\\\\; rubber on your rear tire.
VicW.
VicW.
ORIGINAL: Doc 1
AMEN!!!!!
ORIGINAL: jrdinatale
if you're really concerned with torque dump those drag pipes.
AMEN!!!!!
ORIGINAL: G5jive
I knew that was coming. It actually runs kick *** with them which may be helped to some degree by the HSR 42. At one point I stuffed torque cones in there and ended up dumping them due to that fact that it didn't seem to pull as strong. Now if they were 2" drags, I believe that would be another matter. When I bought the bike, it had a set of longshots on it. Everybody raves how great they are, and they might work well for some, but I found out they weight like 80 lbs. What I lost in back pressure, I made up for in weight saving and then some... It was like a fat girl jumped off the back when I scrapped em!!
ORIGINAL: Doc 1
AMEN!!!!!
AMEN!!!!!
If you seen the tq dip that dragpipes produce at 2000 to 3000 rpm you would have second thoughts, and guess what you ride in that rpm range all day.
