Power Estimate - Woods TW5G
Asked this on another forum also. Curious what your opinions here are...
Any desktop dyno operators able to give me a power estimate for the following\\\\\\;
95"
Woods TW5G @ 10:1
2006 heads setup for this cam
Doherty Power Pack Air Cleaner
Supertrapp Supermeg
Thanks!
95"
Woods TW5G @ 10:1
Supertrapp Supermeg
Thanks!
RE: Power Estimate - Woods TW5G
I have desktop dyno also and have found it to be fairly close .I will say that on most harley combos I run thru it they usually have about 7 to 10% higher reading than actaul dyno test of engine.I have run some v-8 combos out of engine masters mag and found it to be within 2 to 5 % of what they dynoed at.Id say uts good comparision of parts but not best for real judge of numbers that you will get.
anything over 100/100 is great. good usable power with that cam. \\; that cam was developed for the htcc set up \\; another good cam is also the tw6 or the tw6hg. \\; the tw6 , tw5 , tw6hg are all ground off the same center line if memory serves me right. \\; as far as power goes it all depends on the tuner \\;, compression \\; \\;, head work \\; exhaust pipe there are too many variables involved to go and really start chasing numbers.  \\;
