Shovel Dies when I accellerate then comes back when i slow down
My 1980 FXE superglide \\;shovel Idles great, on the Dyno it is strong through all gears. \\; When I am on the road and try to accellerate the entire bike just shuts down. \\; As I slow down almost to a stop the engine comes back with good throttle until I try to gun it again. \\; Here is what the shop has already done and $1300 later I am still having the problems. \\; Replaced Intake Gaskets, jets, complete carb tune up, replaced exhaust gaskets, oil pump and replaced the gas caps thinking they were not venting correctly. \\; I do not want to take it back to this shop, but need some ideas on where to start now.
Thanks for any help
Thanks for any help
RE: Shovel Dies when I accellerate then comes back when i slow down
Super E, It doesnt do it on the Dyno and I saw him go though each gear, it also has 4 plugs. \\; When it was painted (before I purchased it in January) and they did not primar and i can see where paint has bubbled and fallen in. \\; It just confuses me why it wouldnt be affected on the Dyno. \\; Thanks
check under your dash and see if you have a vent hose on the gas tank that may have fallen off or has a hole in it. It's not a bad idea to replace all the rubber hoses on a bike that old anyway. Check for \\;a loose ground wire too. Does it do it all the time or just after it gets warm? If the later, heat up the coil with a hair dryer and see if that makes it run crappy, then do the same on the nose cone.
ahhwataday
03-05-2012 08:12 PM
