will delkron case fit revtech top end
I have a 100" Revtech that needs cases will delkron cases work or is there a problem i want to order them soon and custom crome wants more for the revtech cases then i can get the delkrons for. I would like to use the Delkrons if possible any help would be appreciated
Did you pull the cyl stud threads in the Kia, I mean Rev-Tech, cases??
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Different bolt pattern.
Different case deck height.
Referenced from stock Evo.
I'm home recovering from surgery and checked out a new set of RevTech cases I have and find that the bolt pattern is in deed orphan and the case deck is raised 1/16". If new stronger cylinder stud set up is needed, I have 7/16" sets that I bought out of Mid USA to fix cases with. You will need to retap the cases 7/16x14 for these.
kenberg
05-28-2018 01:01 AM
