Pan/Shovel base gaskets
I hope someone can answer my question. I have a stock 55 Pan with stock 66 Shovel uppers, the rear cylinder developed a serious oil leak at the base gasket, what is the difference between the stock "paper" base gaskests and the heavier metal with silicone gaskets other than the thickness? Would there be any trouble using the heaveier gaskets?
Thanks!
Thanks!
As Randy said, damn good idea to check those cylinder base nuts, and head bolts on those from time to time, especially after initial heat soaks/cycles. Mighty surpising how much more they'll take after heat up.
Another thing to be aware of, is that when doing so, with a solid lifter set-up, be aware of your pushrod adjustment will become snugged up, and may/will result in very poor starting, if you are running them on the tight side to begin with.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
