Sponsored by: Jekill and Hyde
Cam gear conversion: alignment of crank and cam gears
Old 01-19-2011, 09:58 PM
Sharknose's Avatar
Sharknose
Sharknose is offline
Originally Posted by djl
Good information on the key but "gears do not run aligned" is a new one on me.
Maybe I didn't explain what I meant by "alignment" clearly here. The cam gear is parallel with the crank gear, but it sticks out a little farther so that the inner 2/3 of the rear cam gear meshes with the outer 2/3 of the crank gear. Neither gear contacts the other all the way across its width.
He said that gears don't have to be exactly in line like chains do, and he used transmission gears as an example. As you shift, various gears move in and out of position and they don't all have to fully mesh across the width of the gear in order for them to do their job.
Old 01-19-2011, 10:27 PM
djl's Avatar
djl
djl is offline
Received 2,089 Likes on 1,536 Posts
I understand but I have not experienced the problem. Are you retaining the thrust washer behind the cam gear that was used with the chain drive? If so, you should toss it, not used with gears. The cam and pinion gears on some of the gear drives I have installed did not mesh 100% but most did and those that didn't were not off much.
TStephen
Engine Mechanical Topics
12-02-2016 01:25 PM
fergerburger
Shovelhead
16
09-03-2015 12:38 AM
Engineboy
03-27-2013 11:29 PM
twoseas
03-13-2013 02:50 PM
prodrag1320
03-12-2010 06:39 PM
Quick Reply: Cam gear conversion: alignment of crank and cam gears
