answer to my popping noise
RE: answer to my popping noise
I have a 2004 Ultra Classic with the Stage 1 breather, Vance and Hines Oval slip-ons and a power commander. I have installed 3 different maps into the commander and they all make popping sounds. I contacted Dynojet and he said that it is unburned gas that is igniting inside the pipes. They breath better and usually pop on decelleration.
Sounds like we might have to just live with the popping.
Augh!!!
Please don't just 'live with it'.
You can go to DynoJet's web site and search for you nearest authorized DynoJet Tuning Center. They will build you a custom map which will eliminate your problem. Or, it may reveal some other problem but I doubt it.
Those "canned" maps you can download are good if you can't afford to get a custom map but ONLY if you can't afford it AND only if the map matches your configuration EXACTLY.
If you download a map to install in your Power Commander BE SURE to have it tested at a DynoJet facility to gurantee it's doing its' job. This will also ensure everything else is working as it should too. When you bring them your bike ask them for a baseline report showing HP, torque and mixture.
You've already spent the big money, now a custom map wouldn't be much more and it cannot be beat for accuracy.
mmazz365
04-10-2012 05:52 PM
