spark plug heli coil
hay guys new here...bin riding for a while but just bought my first harley...89 ultra classic..it hasnt been running for a while so the idle circuit was plugged got that fixed.popped a new set of plugs in it but looking at the rear head the threads dont look that hot..was wondering if any one has successfully put a heli coil in with out removing the head...was thinking of putting grease around the tap to catch the steel bits...have a bore scope to check cylinders and piston...any thoughts??? thanks sj
cam question
thanks guys.one more question..the head has been shaved and has adjustable push rods with a screaming eagle ign box...i'm thinking it has a cam in itbut not shure..if i put a dile indicator on the lifter and measure the lift from the base circle can i get a good idea what or if it has a cam or what from stock?? sj
You may be able to see that a performance cam is in there, but doubt you know "what" cam.
BTW, pull the head when attending to that spark plug hole thread repair.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
