Sponsored by: Jekill and Hyde
Adapter Bracket Mount for FXR Gas Tank
Old 02-13-2012, 02:45 AM
zyban's Avatar
zyban
zyban is offline
Default Adapter Bracket Mount for FXR Gas Tank
I bought one of these to fit a Dyna tank to my Sportster & was wondering if anyone knew how it mounted.
Old 02-16-2012, 11:23 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
It doesn't look like an FXR mounting, Dynas are FXDs! The FXR tank has an integral flat flange through which two bolts go, it doesn't use anything like that bracket. You may need a Dyna owner.
Old 02-16-2012, 06:44 PM
omgtkk's Avatar
omgtkk
omgtkk is offline
That could be an adapter for the front tank mounts. If so, it looks like it would be plug welded to the frame backbone. Measure the distance between the two outside surfaces of those mounting bosses. If it's around 3 1/8" then it could be an FXR front mount. As Graham said, you still will need something to adapt the rear mounts of the FXR tank. That uses a curved mounting plate with two bolt holes about 4" on center.
mpescatori
05-20-2017 06:14 AM
devilman13xx
06-21-2016 10:06 PM
Fatbob_Bob
Evo Era Parts
11-07-2011 06:12 PM
chengdave2003
06-21-2008 08:45 AM
Winterbiker
05-03-2007 10:18 AM
Quick Reply: Adapter Bracket Mount for FXR Gas Tank
