Sponsored by: Jekill and Hyde
Removing baffles from new Screamin Eagle Slip-Ons
Old 04-24-2007, 09:55 PM
tooldogg's Avatar
tooldogg
tooldogg is offline
Default RE: Removing baffles from new Screamin Eagle Slip-Ons
I knocked mine out with a screwdriver and hammer. I tried a 1.750 pipe but it got stuck. I then used a belt sander to sand the end of the baffleso it's a slip fit. I also drilled the mounting holes out to 1/4 inch to make it easier to line them up with the outer shell when reinstalling. I removed the insulation and it sounds great. not too loud but like a harley now. worth the effort and runs great.
Old 05-15-2007, 10:43 AM
fatboy1584's Avatar
fatboy1584
fatboy1584 is offline
Stage III
i am planning on removing my baffles tonite cause i am saving for the stage 1 upgrade. i was told by the stealer in my area that if i take the baffles out and cut about 1/2inch from the front that they will produce a better sound. has anyone tried this?
Old 05-16-2007, 10:54 PM
Lockman's Avatar
Lockman
Lockman is offline
Pulled mine and installed Thunder Monster baffles from BCT. Sounds louder and deeper than having no baffle at all!! These things are the $hit...IMHO.
Old 12-17-2007, 06:51 AM
ozzie's Avatar
ozzie
ozzie is offline
3rd Gear
Heritage07.....I'm running the Rush 1.75 in mufflers and are happy with them,they give off a nice deep note so the 2in set should
sound even better again
Old 12-19-2007, 02:05 PM
bgknapp's Avatar
bgknapp
bgknapp is offline
6th Gear
I did the same as Lockman for my 07 FatBoy and it sounds great. I highly recommend the thunder baffles. Cut out the old baffles and leave 'em in the trash...
[IMG]local://upfiles/38591/0243897B20EA42BCAFFC55DB6BADB997.jpg[/IMG]
Oldsarge29
12-25-2012 12:56 PM
441amx
Touring Parts
10-03-2011 07:09 PM
WhiteSS
08-06-2009 06:18 PM
Cowracer
02-19-2007 05:14 PM
Naz_Man
08-16-2005 05:49 PM
Quick Reply: Removing baffles from new Screamin Eagle Slip-Ons
