Sponsored by: Jekill and Hyde
Crankcase Pressure
Old 09-12-2012, 09:10 PM
deadheadsmc's Avatar
deadheadsmc
deadheadsmc is offline
Stage II
Default Crankcase Pressure
Oil is comming out of breather vents, rocker boxs, lifter stools. Any ideas???? Motor is a 113 Ultima
Old 09-13-2012, 03:54 PM
springers4ever's Avatar
springers4ever
springers4ever is offline
Default head vents
need to take the vents from the heads that go to the carb,and run them down to a catch can mounted low on the frame somewhere ,,,,motor is pulling the oil from the heads thur the carb under heavy throttle ....i run a s&s g carb on a 05' 107" highly mod motor ...had same problem...search ebay in motorcycle parts for "catch can" ....worked for me !!!
Old 09-13-2012, 04:01 PM
springers4ever
unless the rings are shot and compression is blowing by the rings pushing oil out ,,,leak down test will let you know ....
vbx07
EVO
03-12-2019 08:18 AM
Greg86hd
EVO
06-17-2018 08:20 PM
bagga
EVO
31
08-26-2017 08:25 AM
cc1968
06-09-2010 04:52 PM
38knuckle
Shovelhead
04-03-2008 06:20 PM
Quick Reply: Crankcase Pressure
