2009 Street Bob Changing OEM Bars..
Guys.
I have an OEM front end and wish to keep it that way, apart from the bars.
I am looking at changing out the OEM 10in mini apes and triple tree with the integrated risers.
Before I decide which bars to purchase I would be grateful for some information.
Firstly I would try to source a used upper triple tree, if not, I would have to buy new.
I don't wish to go any wider on the front end.
Therefore, is the top triple tree from a 2006 - 2007 Dyna my only option for the stock width and 49mm forks or is there any other options.
Thanks in advance.
Thanks in advance.
Hello old chap. I get a lot of secondhand stuff through US Ebay, which is worth checking. As for the correct top tree, the chaps over in the Dyna section should be able to answer that. Not many members call in here! You may be able to work out the answer by checking part numbers on line here. Models that have the same bottom tree to yours will be able to swap top trees.
