Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
Not able to install the inner rear pad iron 883
Old 08-29-2016, 01:27 AM
headbanger8383's Avatar
headbanger8383
headbanger8383 is offline
Default Not able to install the inner rear pad iron 883
Hi,
I did it before and it was ok. Now i cant install the inner rear brake pad between the rotor and the caliper...
Any ideas why?
Iron883. (I pushed the caliper inside)
Thank you!!
Old 08-30-2016, 04:58 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Wink
Could be one of several reasons. If you have pushed the piston back into the caliper the fluid may be preventing you from pushing it in far enough. Take care when removing the reservoir cap, as fluid may spurt out. Remove some of the fluid and replace the cap, then push the piston once more, which may give you the extra space you need. Then bleed your brakes and top of with new fluid. I do that every time I install new pads.
Another possibility is the piston has got stuck and needs cleaning, so it can retract fully. Disconnect the caliper and use a suitable cleaner and toothbrush or similar to clean the piston (and the rest of that part of the caliper).
Your rear caliper is a single piston 'floating' type and it may be that the mounting pins are dirty and preventing it from moving freely, so clean at the same time as doing the above. Let us know what you find!
If you don't have one I recommend buying a factory service manual.
Old 08-30-2016, 03:55 PM
beanoboy's Avatar
beanoboy
beanoboy is offline
When I had my 06 Sporty I had a hell of a job replacing my rear pads. After much swearing I discovered I was not installing the 'Rear Spring Pad' properly. I'm sure you have done it but worth a check...b.
O-SiderRider
04-30-2019 11:04 PM
t059736
10-26-2012 08:15 AM
mteed23
03-16-2012 05:49 PM
grizzwold
EVO
09-06-2011 04:53 AM
justanotherjim
04-04-2011 06:09 AM
Quick Reply: Not able to install the inner rear pad iron 883
