How to access the rear master cylinder on a Dyna Switchback
Anyone know how to access, i.e., get the cover off the rear master cylinder of a Dyna Switchback? The owners manual recommends flushing the brake lines every 2 years or 10,000 miles, and the front, no problem. But H-D decided to hide the rear master cylinder behind and under the frame where there is no way to get a Phillips screwdriver on the cover screws. It appears you have to remove the exhaust, then a frame member to get at it. Or Is there a simpler way? Do you disconnect the cylinder from the frame and drop it down? Why in the hell would they locate a component that is supposed to be serviced regularly in such an inaccessible location? Any help appreciated.
Mike, hi from the UK and welcome to HDF.
I can't answer your query, never having owned a Switchback. I do however heartily recommend you buy the FSM, which should answer that and so many other things you will bump into! You could ask again in the Dyna model section, where there should be plenty of Switchback owners.
As already suggested, buy the FSM, that will take you through all the various servicing items of your bike. If you are intending to service your own bike that is the wisest advice we can give. And yes, I have them for each of my own bikes!
Have one for my wifes 2010 dyna super glide,the FSN tells you nothing about how to remove cover, pretty much useless on this...still good to have
